Installed a SBT shortblock in a '99 LRV and am now having trouble getting it to run correctly. While I had the engine out I rebuilt the carbs and replaced fuel lines. I test rode machine and it idled fine and it runs good at WOT, but cruising at speeds between 25 and 45 mph is impossible. I have checked timing and gone through the fuel system again and all looks correct. I'm thinking I may need to go to a larger pilot jet. It has #75 in it. Has anyone seen this before? Can you suggest a jet size or maybe something else to check?
Thanks, Shawn
Thanks, Shawn
