top speed is only 80km now seadoo 2005 gtx
  • top speed is only 80km now seadoo 2005 gtx
    what can the problem be. service is not due yet.
    Re: top speed is only 80km now seadoo 2005 gtx
    Is it supercharged?
      also, what RPM's are you running at?
      Dan Solie -
        Originally posted by Technical Support View Post
        Is it supercharged?
        no 155hp only
          So its running 50 mph and should be turning 7600 rpm, is it? If your rpm's are in this range then you could have wear ring issues.
            Is it supercharged?
            no it's not supercharged
              Yes, I understand that, What rpms is the engine turning at full throttle?
                thankyou 6500rpm
                  no 6500rpm, motor in good condition users no oil at all .
                    Did you recently perform and oil change? Too much oil and you can cause RPM issues. Also, when's the last time you changed the spark plugs?
                    Dan Solie -
