I have a 2000 GTX with the Mikuni BN46I carbs on it and in overhauling them the Sea Doo manual has you pressure check the (injectors) that are in the accelerator pump circuit. The manual states they should hold 13psi +/- 3psi. Mine will not hold any pressure. The Sea Doo dealer says that you have to buy complete carburetors. Does anybody know where to get just injectors? Or does anybody know of a field fix for these?
2000 gtx carb issues
Re: 2000 gtx carb issues
If you are looking for the Diaphram, accelerator pump, then call John at the Watercraft superstore and have him order mikuni part #77 for the super BN 46I carbs 866-957-9277SBT Tech Support is here to help with your problems.
