96 XP 800 spark
  • 96 XP 800 spark
    Can anyone give me some advice in regards to why my 800 has spark when i connect the battery and try to start but on the second try i have nothing??? I put a new coil in the ski, took the whole brain assembly out of my 96 gtx and it does the same thing??? i pulled the motor out of the ski and took out the stator and tested it and all three yeelow leads have .8ohms nothing to ground, and the trigger has 232 ohms which in the book it shows 242 ohm +_ 10% which would be ok????
    Any thoughts would help
    Re: 96 XP 800 spark
    Sounds like a bad stator.
      Re: 96 XP 800 spark
      Thanks for the info, it was a bad stator got it running again now i have another issue.
      I keep blowing the boot on the rave valves part and throwing oil all over, this last time it melted the cap, any ideas??
      Please advice, thanks
        Re: 96 XP 800 spark
        clean the boot and use tie wraps on the bottom { small tiewrap}
          Re: 96 XP 800 spark
          I have small tye wraps already on the bottom new boots new caps but it keeps blowing apart and has even melted one of the caps...
