I'm about to purchase a cylinder exchange and have not found any specific instructions for cylinder replacement. I've read the short block replacement instructions. I also have the Sea-Doo shop manual. The manual describes using a circlip installation tool and a piston pin puller tool. Do you all think I'll need either of those tools? I think the new pistons come with caged bearings so bearing installation should be easy. What about removal?
Second question; what do you all recommend for selecting the right base gasket thickness? I'm guessing that I need to specify it when ordering the exchange kit, but how will I be able to determine the right thickness prior to installing the new cylinders? I read about the squish test; is it meaningful to perform that on the existing cylinders and pistons?
Michael
Michael
