96 SeaDoo GTI -at idle, out of water, revs faster then slower, cyclical, repeatedly
  • 96 SeaDoo GTI -at idle, out of water, revs faster then slower, cyclical, repeatedly
    I am stumped! [ Searching web, I cannot find similar problem ...] --- 96 SeaDoo GTI [#67], at idle, out of water, engine revs cycle up and down [faster then slower], then repeats, about 5-6-ish sec cycle. --- I havent checked actual rpm, but high about right at 1500ish, low maybe 800ish. --- Carb rebuld last year with Mikuni kit [I did it] -taken off and rechecked [all ports clear, good pump, good needle valve, consistant 40 popoff both carbs, filters clear - all appeared good with carbs.] -- Timing appears to be 15-20d BTDC at idle [no spec on that], and does not appear to change much when reved up to 6k rpm [ manual says spark should retard with higher rpm...odd?] A second "sister" 96 GTI, which idles and runs fine, same thing on timing, idle and rev up. ... Neither boat appears to have had the mag cover off. any ideas? // Tks *much* // andy in orem
    Click image for larger version  Name:	- 60 timing.jpg Views:	0 Size:	35.8 KB ID:	338093 Click image for larger version
Name:	- 67 timing.jpg
