95 XP800 carb rebuild
  • 95 XP800 carb rebuild
    Rebuilding my carbs on a new to me 95 xp800
    I'm confused on the pop off setting for these carbs, the charts say 40-56 with an 80 gram black spring. I tried setting pop off and am way low, like around 30psi. Someone told me you cant get 40-56 with the black spring and a 1.5 seat. But the parts manual for the 95 xp800 shows the black spring.
    Seems like something isn't correct, either the charts are wrong on the pop off, or spring is wrong, or maybe the seat isn't supposed to be 1.5?
    Can anyone tell me what the right combination is? I'm also curious if anyone knows why these carbs have bigger jetting than the 96 XP carbs and if these carbs are as good as the 96 carbs.
    I've been searching for days trying to figure this out.
    Thanks for any help on this
    Tim
    I just looked at the parts manual again and it shows an N in front of the spring, which means new part. So something is up with that, maybe it originally came with a different spring?
