1996 seadoo gtx, DESS no beep, will not start, no lites or info center data
  • 1996 seadoo gtx, DESS no beep, will not start, no lites or info center data
    checked and cleaned post and lanyard....
    with multimeter checked and tested all fuses in
    front and rear elec boxes.
    12 volts at battery, able to jump selenoid and engine cranks
    with lanyard off i pressed start button 5 times.
    no beep,no lites or info center data
    with lanyard plugged and DISCONNECTED 3 wire plug from post WIRING
    i checked continuity
    1.from post to male connector...NO continuity
    with lanyard "OFF" is was able to get continuity on blk/white and blk/yellow
    from post
    reconnected 3wire post connections...have continuity from post into mpem
    and good ground as well
    **** if i disco the post and jump and ground the 3 wires leading to the mpem
    gauge lites turn on. get time date etc on info center
    and if i press start 5 times. i get 1 short and 1 long beep
    can anyone help me determine the cause?
    I hope its just the lanyard, post or MPEM
