ok! once again, a new problem. I took both ski's out on saturday for a ride and make sure i had no problems for the season. I had been riding for about an hour, all was going great. Both ski's were handling perfect, running smooth, GREAT! I decided to go back towards the launch and had turned around. When i went to speed back up, the engine revved, I slowed down. I immediately pulled the lanyard, as it was just free revving from no load.
I pulled the rear cover and turned the motor over. The shaft is spinning all the way to the rear, pfrom the engine to where it goes through the glass. I see no movement of the impeller through the jet pump.
Not sure is this is the same as an outboard prop, and has a hub..
Jus looked under and got someone to turn engine. shaft is spinning with motor. the splines are in BAD shape though. cant tell if it is shaft or impeller. How much should this cost, in labor for taking it to dealer, as im about to be working two jobs and need these done ASAP!
What could this be. Never had this problem so I have no clue.
