I know the compression should be check at WOT but what kinda compression should you see by just turning the engine over and not starting it on a 96 GTX 787?
Also i am wanting to do away with my stock pump and add a mikuni high flow pump to feed both carbs, do i need to remove the stock pump or can i just block off the pulse port on the stock pump?
