i have a 2000 gtx di which has supposedly had the engine rebuilt, put new plugs in it and ran it on the water for a few minutes and it pulled fine and revved to about 7000 revs, then it started dying and managed to limp back while cutting out a couple of times. Dealer hooked it up to the machine and showed no fault codes. I took the ski home and took the plugs out and there was a small amount of water on each plug which i dried off with a small soldering gas torch, i tasted the plug and it is salty. I realise the engine is taking in water on both cylinders to have done this but would like to know what you think is the probable cause, are there any common problem areas that would have caused this? Any ideas greatfully received and listened to
Thanks in advance
Thanks in advance
