No Beeps when placing DESS on pole. starter does not turnover. Battery has to be how many volts to turnover charged over nite. :(:(
2000 gti
Re: 2000 gti
Battery can spin the motor down to 10v +/-. Need more though to produce spark.
The no beeps tells me that you either have a bad ground somewhere, or your DESS post is bad.
Push the start/stop buttons 5 times quickly.. Do the gauges light up and you get a beep? If so, DESS post probably, if no, then grounding issue (or, really dead battery)Dan Solie -
Re: 2000 gti
Did you perform the start/stop button test? Yes, it could be DESS, and other things..
I mentioned, in post #2 what you need to do, and what it could be caused by.. Did you read that?Dan Solie -
Re: 2000 gti
You need to start checking ALL the black wires you can find..
Did you do any work to the ski recently?Dan Solie -
Re: 2000 gti
Not recently. This happened at the end of the year last year. Going across the lake it quit running. Check it out and it was blowing the 5 amp starter fuses found broken wire in small blackbox next to battery fixed wire connection. The fuses are fine now. When checking all black wires in the comnnectors etc.
Re: 2000 gti
You can just buy the post.Dan Solie -
Re: 2000 gti
no.. the MPEM holds the program, the DESS post just relays the code from the key to the MPEMDan Solie -
