I ordered a replacement engine for my '01 GTX RFI (787) from SBT.
I've been working with engines for the past 35 yrs. And I know the importance of following guidelines on breaking engines in - Of which I followed SBT's meticulously.
The engine currently has 7hrs on it. I have not gone to WOT yet.
The engine runs good with good power.
Checking after 2 hrs. I found 115# on the back and 120# on the front.
I was expecting something in the 130-150 range. I've used two different gauges I haven't seen any increase.
I checked the oil pump output at injectors prior to firing up.
Oil is dropping normally in tank.
Plugs seem a bit oily if anyting, so I know I have been getting enough oil.
I Believe I did everything properly , and I have a new engine without good compression
where do I go from here?
