sunken float 2001 GTX
  • sunken float 2001 GTX
    What do you do with a sunken float ? I put it in Hot water thinking as it heated air would come out of the leak, wrong ! It puffed up and no air bubbles at all. I drilled a small hole in the end and got the fuel out, pluged it with JB weld. May work ? Never did find a Leak, must be very small. Any other suggestions. Can you buy a new float only ?,,,Tony:)
    Re: sunken float 2001 GTX
    Called Walt's, they have lots of them. 12.00 no more problem sea doo has the floats NEW inc. magnets Tony G:)
