No spark
  • No spark
    Have an '95 XP 800 with no spark. where do I go? I have good compression, good fuel, good cranking and all the fuses are good.
    Re: No spark
    Any recent service to the ski? How do you know you have no spark. Are you visually confirming that?
    Dan Solie -
      Re: No spark
      yes I can see that there is no spark during a spark test. Any ideas?
        Re: No spark
        Likely a problem with your trigger setup in the front housing.. A common problem for the early 800's.
        do you have a shop manual? if not, you will need one. www.seadoomanuals.net
        Also, just for kicks, trim back the plugs wires. Pop the boot off the wire and snip 1/4" of wire off.. Put the boot back on..
        Dan Solie -
