96 GTX 787 Carb tuning ?
  • 96 GTX 787 Carb tuning ?
    What should the Carbs be set at on this ski? Should I go any turns out on the high? Which is which anyway? Are the top adjusters high speed and botum low?
    Re: 96 GTX 787 Carb tuning ?
    1-1/4 +/- 1/4 for the lows. Highs should be seated at 0.
    The lows are the ones with the "T" handle. Highs usually have a cap on the top to only allow an adjustment of 1/4 turn.
    Dan Solie -
      So should I adjust the high at all or leave it set at 0?
        keep it at 0
        Dan Solie -
          took it out today.bogging out at 3/4 trottle.then a big *** wave ate me didnt die but i shut it off about 5 min later.now starter not engaging.
            how fast should this 787 go.
              In the GTX?? Low / mid 50's
              Dan Solie -
                99 gsx lmt 951 borring ?
                Do i need to mach the rave valves with 5 over pistons?
                  Re787 GTX ONLY GOES ABOUT 30MPH
                  The owner of the ski put a sbt motor in.could he have put the rotory valve in wrong?
                    Re: Re787 GTX ONLY GOES ABOUT 30MPH
                    How long ago was the motor put in? Has it run right since you bought it?
                    Dan Solie -
                      no. bought sbt motor in october.it still will only go 30.im at 1/1-4 on the low speed i took the oil injection out. should i adj carb diff.
                        What ratio are you pre-mixing at?
                        Dan Solie -
                        • #13
                          40:1
