oil in super charger
  • oil in super charger
    it is common for the intake hose to have oil residoo in it
    it was in there before i raplaced s/c and is in there after i replaced it
    what is the oil seperator?
    Re: oil in super charger
    yup. common. That's why people install catch cans on the modified units.
    Dan Solie -
    04 RXP (the "Instigator")
    94 xp (freestyle mods)
    95 xp (faster than the 94)
      cool
      is it also common if you dont use seadoo oil on these 4tecs for the oil to turn very slightly milky under the oil cap
      i was told these by someone else and they said seadoo oil is blended so it doesnt turn milky
        never heard that one. I have seen seadoo oil get milky.. when it's mixed with WATER..
        You positive you didn't suck up any water, or have a leak somewhere?? You mentioned replacing your S/C.. did you do it right and yank the motor?
        Dan Solie -
          yes we yank motor and got the peices out of it thats all good now
          i just got a little milky like a head gasket went but some told me that if ya dont use seadoo oil it will get that away, my thought was b/s
          heres a quistion for ya what is the stock fuel pressure on it
          i put an x charger on with the rffpg and set it to 62 but ran like crap to rich would hardley run over 7000rpm
          but as i lean it down it getting better and getting close to 8000rpm with better out the hole but still like it needs less dont want to got lean
            What does it mean to yank the motor?
              You will also get oil in the intake hose if you over fill the crank case with oil, only fill the oil to the center of the bump on the stick.
