I have been given a '91 Sea Doo GT. I was told it possibly had a bad starter. With a new, fully charged battery it will turn over with the plugs out, but not with the plugs in. Using a battery charger that has a 2amp, 10 amp and 50 amp charge cylce, and also a 125 amp start setting, if I hook up the charger at 10 amps it makes little difference. 50 amps turns it over, but stills slow. At the 125 amp start setting, it spins over good, and the plugs are firing, but it will not start. I tried checking the compression and, if I checked it right, it didn't
have any. Now when I checked compression we had removed the exhaust pipe. Would the pipe being off effect the compression? Is this thing shot? I am new to watercraft of any type. I see books for maintenance, but is there a book for dummies that just explains how they work - like where the water comes in and the path it takes?
