SC PUMP
  • SC PUMP
    The vane can be ground down and reshaped if it's not too big - otherwise you need to send it to www.impros.com for some reconstruction. The scratches will make you cavitate out the hole if bad enough. It will only get worse, too.
    I sucked up some rocky sand and scratched the wear ring, but worst of all it looks like one vain has a dime size piece missing on the front edge. How will this effect my performance and should I replace the entire pump?
      Thanks, I will try to file down the pump vein. If that don't work, it looks like IMPROS.com is the cheapest way to go. Thanks again
