My 98 GTX RFI (bought at auction and havn't had it in the water yet) starts easily and seems to run fine, but doesn't want to idle at all. I have no idea what adjustments there are that I can make and what's controlled electronically. Hopefully someone here can help me out. It has new plugs (BR8ES). The gas in it may be partly the problem. I have no idea how long it sat before I bought it. I will drain it this weekend and replace with fresh gas to make sure that's not partially the problem. Last weekend I started it up and the langer I had it running the better it seemed to get. How long should it take to warm it up enough to idle? What should the idle be at out of the water anyway? Any help would be much appreciated.
Sean
Sean
