I'm a first timer at winterizing my seadoo GTS. I poured about gallon of antifreeze into the engine return hose. Drain hose and water supply hose were pinched. Took off the hose pinchers no antifreeze came out. Cleaned out a clogged drain hose. About 1 quart came out. I expected most of it to come out. I then blew into the water outlet hose. More antifreeze came out the exhaust but I could hear bubbling water, not sure were from. Is this bad?
too much antifreeze?
Re: too much antifreeze?
take out your spark plugs and bump the motor over with the starter.. If antifreeze comes pouring out of the plug holes, then yes, too much. No antifreeze come out of the plug holes, perfect!Dan Solie -
