Molykote 111 substitute
  • Molykote 111 substitute
    is there a substitute for this? its used on cylinder bolts on my 02 951 DI
    Re: Molykote 111 substitute
    Go to Napa or autozone and see what they have, I'm sure they have some type of molycoat grease.
      Molykote 111 is a silicone based water valve and plumbing lubricant/sealant. Molykote is the brand name, there is no moly in this product. This product is normally used by BRP to lubricate the oil seals and their mating surfaces or as a lube/light sealer for threaded fasteners....I usually just use plain old marine grade grease. In BRP's older service manuals they called for synthetic grease instead of the Molykote 111 for the same application(s). I use Bel-Ray or Silkolene. http://www.belray.com/consumer/product.fsp?pid=1326 <OR> http://www.silkoleneusa.com/img.aspx?OBJ_ID=1048935
      John Kubiak
      Las Vegas, Nevada
      Sea-Doo Tech 13736
