what can i do to my 96 gti to give it a lil more pep:)
96 gti
Re: 96 gti
not too much... The easiest mod you can do and not risk putting too much strain on the motor is to pull the stock airbox off and replace them with aftermarket flame arrestors (F/A's). You will have to pull and re-jet the carbs.
Call Bill @ Watercraft Magic...
(626) 914-9509
444 W Carter Dr Ste C
Glendora, CA 91740Dan Solie -
04 RXP (the "Instigator")
94 xp (freestyle mods)
95 xp (faster than the 94)
Re: 96 gti
Depends on the carbs off the 95, and if your xp is a 717 motor (not a 787).
If it is a 717, then you should be able to just swap them right over. You might have to play with your impeller pitch a little too.
Don't expect miracles from that old 3-seater. You will gain 1..maybe 2 mph, and a little (and I mean a little) more grunt out of the hole.Dan Solie -
Re: 96 gti
does it look just like the 96?? With the sparkplugs straight up and down? If so, then yes, it's a 717. If the sparkplugs are slanted with the motor to the left (drivers, port) side then it's a 787.Dan Solie -
Re: 96 gti
yup.. also, I would reccomend downloading your manuals... for free...
www.seadoomanuals.netDan Solie -
