Well, if first you don't succeed try, try again. Well at least as long as the money or my sanity holds out.
99xpl, rebuild carbs, fly F/A, rejet kit (high 170 - 1 1/2 turns, low 68.5 - 1 turn, I bought this as a kit, thought the lows were strange since stock is 75), R&D 49CC head
Tuned lows for max RMP at idle, started tuning highs, was getting about 9000RPM. Didn't notice any drop off at high speeds. Started high speed straight runs for plug coloring.
I couldn't get any color on the Mag plug, was thinking that I might be rich enough to wash all carbon out. Think I've heard about that happening.
PTO plug was giving dark color on plug, though it was looking good.
Started WOT turns, engine died. I was below half a tank so I filled it up thinking it was fuel starvation. Died again on WOT turns.
Pulled head and PTO piston had signs of detonation on crown and light scoring on walls. Mag piston was OK. Something that caught my eye was the O rings on the head. They had become thin in spots and had starting to melt(?) to form ridges where the head met the block.
I was wondering if this jetting sounded OK, particularly the lows. Could the Orings have been defective and allowed water into combustion chamber. Scoring was all around piston. I'll have to see if I can post some pictures if it would help.
Also wondering about RAVE line off of PTO side of block, how can I check to see that there is no air leak here.
Very light scoring on walls, possible get by with a light hone and a stock size piston?
Thanks for the help.
Jim
Jim
