Oil Change
  • Oil Change
    I would like to change my oil on my 2000 Sea doo GTX ME. I've been running Pennzoil TC W3. Bad yes I know!! However; I want to now run Sea-Doo XP-S 2 Stroke Synthetic Oil. Do I somehow need to drain all the oil from the engine. And if so how?
    Re: Oil Change
    Use an oil extractor to suck it from the crankcase and the oil tank. Watercraft superstore sells them 1866-957-9277.
      Re: Oil Change
      Super!!! any idea how much oil the crankcase hold?, and also where would enter the crankcase?
        Re: Oil Change
        The GTX is the 951, there is no 2-stroke oil in the crankcase. Just suck the tank and oil lines dry. Make sure you bleed / prime the oil pump before you fire it off with the new oil.
        Dan Solie -
          Re: Oil Change
          Which motor is in you ski. I know my sister's GTX is the ME, and has the 787 RFI, yet one of my uncles has another one with the 951 CARB motor. which motor do you have?
          Ken Folsom
          2008 RXP-X 255
          2003 GTX DI & 2003 GTI LE
          2000 GTX RFI Millenium Ed.
          1990 Mastercraft 191 - Ford 351 Windsor GT40
          Team Mastercraft
          USA Waterski - 2003 KD CR7
            Re: Oil Change
            The ME should be RED. The GTX-RFI should be green/gold. The GSX is also red, but with an RFI or carb'd motor.
            Eonpoint, there is a difference, if you have a 787 motor, then you do have oil in the crankcase...
            Dan Solie -
              Re: Oil Change
              947 or 951 cc engine.
                Re: Oil Change
                the GTX we have is green, but is the ME. it has the 787 RFI motor. But, one of my uncles has another ME and is blue, and this one is the 951 CARB motor, same as in the RX and XP.
                Eonpoint - check the sticker where you pull the seat off and see what family the engine is in. should say 951.2 if its the 951
                Ken Folsom
                2008 RXP-X 255
                Team Mastercraft
                  Re: Oil Change
                  Eon, my original post was correct then. There is no oil you have to worry about in the crankcase for this procedure.
                  A green ME?? You have the International version. I take it you didn't buy it new? It was never meant for sale in the US... Probably originally from Canada, or Japan. That's where most of the international's are meant for.
                  Dan Solie -
                    Re: Oil Change
                    Dsolie the man!! 2 for 2. I greatly appreciate it. Now next question how to bleed and prime the oil pump. LOL!! you open the door.
                      Re: Oil Change
                      Eon - The bleed screw on the motor is on the front of the oil pump, which is on the front cover of the engine. I believe it is a 10mm head.
                      Dan: We bought the ski from my cousin who lives in Birmingham, and he Bought it new in Pelham, Alabama. They bought it new at the end of 2000 and sold it to my sister for cheap since it needed a top end rebuild. I am curious now on how it was sold in Alabama though. I will look into this!
                      Ken Folsom
                      2008 RXP-X 255
                      Team Mastercraft
                        Re: Oil Change
                        Eon... Manual time.. It's worth it's weight in gold...
                        And!! It's FREE!
                        www.seadoomanuals.net
                        Dan Solie -
