I just put a rebuilt motor in my 95 gtx. Turned it over for the first time and it fired up. It ran for about 10 sec. and shu down. Pulled the plugs and its spitting alot of raw fuel out both plug holes and a little out the carbs. What would cause the flooding issue?
657x Flooding
Re: 657x Flooding
Leaking or failed needle and seat. Did you re-build the carbs??Dan Solie -
Re: 657x Flooding
Carbs or really poor rotary valve timing...Dan Solie -
Re: 657x Flooding
You will have to open it up to see what's in there now.Dan Solie -
Re: 657x Flooding
Still the seats.. The pulse just tells the fuel pump to pump.. The fuel pump, well pumps the fuel and it's up to the N&S to regulate the amount of fuel entering the motor.Dan Solie -
Re: 657x Flooding
New seats are in and still doing the same thing. Pushing fuel out the carbs and flooding it out. Pretty sure i timed the rotary valve correct but, What is the exact way to time the motor? What elese could be the issue?Last edited by Raceball0396; 06-04-2010, 05:10 PM.
Re: 657x Flooding
Okay.. did you check the pop-off?? Pressure the carbs for a leak down test?? is your diaphragm resting too much on the needle lever??Dan Solie -
Re: 657x Flooding
The needle arm should be flush with the inner carb body, or just a hair below. The diaphragm nipple should rest on the needle but not apply too much pressure, or it will be holding the needle slightly open (causing the flooding you are having).
Go the the tech articles on this site and there are very detailed instructions on how to check your pop-off as well as how to pressure test the carb.
You will need to buy a $40 gauge to do it... Where are you in Florida?? There are many shops in FL that can test them for you for a small fee.
Also, just to make sure... The seat retainer and screw are in, right? That little piece of metal that wraps around the seat to hold it in place??Dan Solie -
Re: 657x Flooding
No, needs to be a jetski place...
Which is closer to you, Ft. Pierce or Dania Beach?Dan Solie -
