Hey guys, I have another question on why my 95 SPX is bogging in the water..I took it into a nearby shop (bargers all sports) in Waco, TX today and they asked what kind of oil I was running. The oil I am infact running is not TCW-3 approved and is for 2 cycle engines such as motorcylces, scooters, etc..I was told it was okay before using so I just went ahead...I told them this and they said this could be why I have a low 120 compression and I may have some scoring..Could this be a reason why it bogs? If so, would a top-end be fine and do the trick?
Still bogging
Re: Still bogging
Having a higher ash concentrated mix can harm the motor... You should be using sea-doo oil to eliminate that problem.
120 might be fine... It's all about being EVEN, or close to, between the cyls. Gauges are off, unless you are using a calibrated snap-on or other high end gauge, the numbers are meaningless to me, as long as the numbers are close to eachother.
What plugs are you running?
You can pop the head off in just a few minutes and take a look at the cyl walls and piston too. It's an o-ring head, so there are no gaskets to replace.Dan Solie -
