Hey I just got my newly rebuilt motor and bolted on the exhaust, flywheel, rotary cover and the carbs. I was reading the manual and saw I need to put oil in the balancing thing. On the manual, there was a fill in the case to put the oil. My engines isnt there. There is the area where it would be but there is no screw tapped into it. Do I need to put oil in their or will the oil from the tank go in there automatically? Im just confused. Also whats the next step I need to take before putting the engine back into the boat. I dont want to mess this one up like I think I did the last. Thanks in advance for the guidance. I need the steps involved in putting this boat back in the water. -Casey
Newly rebuilt SBT 787 install help
Re: Newly rebuilt SBT 787 install help
Casey, sbt fills the counterbalancer area with oil as we build the engine. You will need to hook up the oil lines to the rotary valve area ( each side of the case ) to get the oil from the oil tank back into this section to lube the rotary shaft.SBT Tech Support is here to help with your problems.
