I have replaced the engine in one of my 1996 GTXs with a SBT short block. We went through the engine break-in procedure last weekend and everything appeared to run just great. By the end of the 2nd tank, it reved great, had a good power curve and response.
My sons are at our lake house this weekend (I have to work) and report back that it is now not running well. They put it in and ran the battery down cranking last night as it was hard to start and the fuel valve was turned off! After they got it started, it ran great for 5 to 10 minutes and then just died. They told me that it wasn't like the DESS key being pulled; that it just suddenly ran poorly and then died. They couldn't get it restarted (said the battery was weak) and towed it in. I told them to pull the plugs and make sure that something hadn't happened to the engine. They said that it turned over fine then and thought the battery was the issue. They left it on the charger overnight.
They cranked it again today and said it was again hard to start and ran a little rough; like the timing was off. After idling for a few minutes, it began to run fine again and they took it out. After 5 to 10 minutes, with it running perfectly normal again, it again suddenly died and was hard to restart. Now they are calling long-distance to see if I can point them in the right direction.
I need to add that while the engine was out, we cleaned and adjusted the carbs, replaced the filters, put in a new RV shaft, replaced the RV valve and replaced the RV cover (all by SBT).
The oil pump was primed and we ran extra oil in the first 10 gallons as recommended by SBT.
Anyone know where to go from here???
