My doo was shutting down, like the killswich was being depressed, rebuilt the carbs, checked for loose wires, One of my crank bearings welded its self to the crank and another bearing was shot, I know this wasn't good, could this have been my problem?
94 xp shutting off
Re: 94 xp shutting off
Yes, that is the problem. Make sure your carbs are set up correctly so you donot run the engine too lean.SBT Tech Support is here to help with your problems.
