Was having hesitation problems during acceleration with my Di....shop suspected fuel pressure issue - computer check showed that the fuel pressure reaches the right max pressure - but is slow to build the pressure. Could that be the fuel filter ? and which one is more important - the pad at the bottom of the fuel pump or the canister on top - or always do both ? Guy at the shop says not to worry about the one on the pump - that doesn't make sense to me ? Any help / comments are appreciated...Thks
2002 GTX DI - Fuel PRessure / Filter Question
Re: 2002 GTX DI - Fuel PRessure / Filter Question
usually it's the can on top that fails... and when it does, so does your motor... It's also the more expensive of the twoDan Solie -
