I just bought a 2001 RX-DI and it has been sitting outside not running for about 3yrs. I put a new battery, gas and, oil and started up on flush kit and garden hose runs good on pressured water but when at lake doesn't suck water????? Is there an impellar or is a line clogged, any help would be appreciated. Thanks
2001 RX-DI High Temp alarm
Re: 2001 RX-DI High Temp alarm
Originally posted by Rocky 1 View Postcheck the line thats runs to the pump force water out thru thr pump dirt dobber move in and block them up
Yes, the one opposite of the flush. Disconnect it at the "T" and blow into the line that goes to the pump area. If you can blow freely, then it's further up the line. If it's clogged, some wd-40 followed by a good air compressor blast usually clears em out.
If it's further up the line, trace the lines off the "T" and disconnect from the motor connections. Repeat the blow trick on those lines..Dan Solie -
04 RXP (the "Instigator")
94 xp (freestyle mods)
95 xp (faster than the 94)
Originally posted by Rocky 1 View Postchech to see if the port is pluged on the front
