Recently replace the carb linkage on the ski. Tried to set it the same length as the old one that broke. Since I did this, my engine boggs at low to mid level speeds but runs fine once it catches. Also hard to get it going on a cold start. If this is my problem, any suggestions as far as whether to draw in the linkage tighter, or expand it? Thanks for any suggestions!
96 SPX Bogging Down
You have to sync the carbs. Back the idle set screw out so it doesn't contact the stop. Set all the carbs so the butterflies close at the same time.SBT Tech Support is here to help with your problems.
You just adjust the linkages till they are all closed at the same time...say the back one is closed and the front is slightly opened. Lengthen the linkage slightly till the front is also closed. Then readjust your throttle cable for proper slack, and reset your idle speed screw - 3000RPM out 1500 RPM in the water.SBT Tech Support is here to help with your problems.
Don't worry about the butterflies not being closed at the moment. Tech wanted you to turn out the idle screw so that the butterfly valves were closed. This will give you a better reference point to ensure that both butterflies open at the same time. Once you get this done, set the idle back to 1500/3000 rpm in and out of water respectively. The butterfly valves will open up as you idle it up in this step.
