2000 rx starts, idles,runs great except @ mid range if you ease into throttle or hold throttle @ mid range, engine starts slowing down and will die. engine will start right back up and idle & run fine except @ mid range. holeshot from idle is also perfect. Tried adjusting low speed needles on carbs but no help. high speed was left alone @ 0 turns. any ideas, could it be carbs or rave valves? compression and spark are fine. Thanks for any help.
2000 rx mid range bog
Re: 2000 rx mid range bog
accelerator pump?? Sounds like you are too lean to me. Have you cleaned the carbs?Dan Solie -
I would say it's time to look into the carbsDan Solie -
