I actually had in mind if there was anything wrong with using it as THE gasket .. by itself. I probably could take the carb off carefully and then re-use the original, buttering it with the blue silicon. It would take a little while to get a new paper gasket, so that's why I was asking about the gasket-maker stuff.
Thanks all for the replies.
