#1 backfires, electronics ohm out to specs, carbs clean and adjusted to spec, rotary valve feels to b timed right, only backfires out of #1, anything common to cause this and where should I go next?
Thanks for the help
ASE Master Tech
ASE Advanced Level Specialist
GM Certified
Cadillac Tech
Been fixin and riden skis since 05
