Our 1996 GTi quit about a week ago. It has spark, gets fuel, air, etc.. Thought it may be a carb problem and when we got down below the spark arrestor one of the screws that holds the breather box was missing. Once the carbs were removed the screw was found in the intake manifold by the rotary valve. Upon removal of the intake and rotary valve cover we found the screw stopped the rotary valve from spinning. It is my understanding the rotary valve shart turns from the middle of the crank. In looking at a parts book I see there is a spring on the far side of the shaft as well. Can the shaft spin intermittently? Ours does. If it is supposed to do this, what would make it have proper port timing? If it is supposed to turn full time, what would make it sometimes turn and not other times?
Any thoughts or suggestions are appreciated!
Thanks!!
Thanks!!
