Got a 97.5 ski that I bought as a non runner. Carbs were leaking fuel into the motor and the fuel switch was bypassed.
I've replaced the fuel line components and replaced the worn needles and seats.
Motor now not filling with fuel and starts up easily but won't run right. These are the symptoms....
Running on hose the PTO cylinder seems to run fine but the front seems very lean - motor ranaway a couple of times.
Put ski in water. Started fine and idled about 1200 (I did adjust throttle screw when carbs were off). Tried giving it gas and it got to about 3200 and would go no faster.
Pulled plugs (new) - PTO plug was coloring up nicely but Mag plug looked new (wet with oil). Also I could feel heat around the PTO cylinder but not the Mag.
Good spark to both plugs (trimmed Mag lead back but was not needed).
Stripped Mag carb and checked low speed jet, etc. No blockages. No change to hose running.
Checked pop off - about 24 psi.
Compressions - 150 both cylinders.
Reeds looked OK from a visual inspection - should I pull them and look closer?
Carb. regulator diaphragm has no signs of damage / holes but not sure what it should look like new so should I change this?
Any thought / suggestions on what the problem with this ski is would be appreciated.
Colin
Colin
