40mph on a GTX rfi
  • 40mph on a GTX rfi
    On a GTX RFI year 2002, i change the fuel pump because of the filter and clean the injectors to make sure that every thing is OK, but still it goes only 40 mph.
    Any help
    What top RPM are you getting? Have you done anything with the throttle cable?
      don't know exact rpm's, but acc is good and no too much rpm,s like reving and not moving. nothing with the throttle cable.
        Try new plugs - other than that you will need a Sea-Doo dealer to hook it up to the computer for diagnostics - it's pretty common to need new injectors on an RFI ski. The computer is the only way to find out.
          i will check these steps and if no answer i will go to the dealer
          thanks
