2001 RXDI Running Rich
  • 2001 RXDI Running Rich
    Just replaced engine and is now running rich,fouling plugs. Oil pump is adjusted to proper settings, marks are aligned but seems to be dumping too much oil. pinched off oil supply and ran it with oil mixed with the gas, ran better and didn't foul the plugs. Will it damage the engine in any way if i discontinue using the oil pump and just mix oil with the gas just like any other 2 stroke?
    Re: 2001 RXDI Running Rich
    running pre-mix can damage the fuel injectors.
      any idea what's causing the plugs to foul? when i pull the plugs, they are very black and wet with fuel/oil mixture.
        It's because you are over oiling.... Remove the pre-mix fuel, run regular fuel and let the oil injection do it's work. Also, you will need to replace the plugs.
        Dan Solie -
          i had already removed the pre-mix for the break-in, put fresh gas along with a new fuel module that came with new filters. still ran rich, so i wanted to find out if the oil pump was dumping too much oil, i pinched the oil supply, then pre-mixed again, it ran better, but the plugs are still very wet but not oil fouling. what could cause it to run so rich?
            You injectors could be trashed, your plugs could be toast, your in tank and out of tank fuel filter could be fouled with oil....
            Dan Solie -
