Compression Question
  • Compression Question
    Quick Question: What should the compression be on a 1996 Sea Doo GTI? It has the 717, twin carb engine.
    Thanks in advance!
    Re: Compression Question
    Between 130-160 depending on the internals, usage and the type of gauge you are using.
    Dan Solie -
    04 RXP (the "Instigator")
    94 xp (freestyle mods)
    95 xp (faster than the 94)
      Thank you Dan. Stock internals, ordinary usage and a gauge we got at Harbor Freight.
        The main thing about compression tests is to make sure your cyls are within 10% of eachother. So, if one cyl is 140, the other should be between 126-154... Usually, any more than that and you have some serious issues with the lower cyl.
        Dan Solie -
