I'm only running on one cylinder... '96 Challenger 787.
The recent background here is - found magneto and stator were destroyed from a mag bolt that had worked loose. I replaced both pieces with good condition used parts and reassembled. Carbs were just rebuilt (except for jets and needles), new fuel line, new oil lines, new gaskets all around.
She will start and run but only PTO side cylinder is firing. Compression is good on both (approx 160) and I replaced the ignition coil with a brand new piece from babbitts just for shizzies. I have spark on both sides but it seems to be somewhat weak.
When I start it and idle (it will idle with some help) for a couple minutes, the front mag side cylinder will fill up partially with fuel and the spark plug will be soaked.
I'm wondering if the mag side carb is possibly flooding the cylinder... Or if the weak spark is to blame... I'm having suspicions of a bad mpem or cdi. The charging system fuse was blown when I first discovered the magneto and stator problem. Otherwise the electrical box is clean and tidy.
Could the loose bolt that got jammed between the stator and magneto possibly shorted the system and fried either the cdi or the mpem???
Anyone been through this?
