I need help big time. I have a 1998 sea doo sportster. The starboard side enigne keeps acting like it floods out and dies after starting it. It will start but if you let it idel it is gone and will not start back up for several hrs. If you throttle it up then it is OK but once I try to dock it, at idle or low throttle, it dies. It has new spark plugs, new fuel pump, new filter, rebuild carbs, new spark plugs, good compression [basically everthing I can think of is new]. The mechs seem to have no idea. Can you help???
thanks
thanks
