2002 Seadoo GTX DI Hose Dilema
  • 2002 Seadoo GTX DI Hose Dilema
    I have two hoses that I'm trying to determine where they connect. The parts drawings show both of them connecting to "crankcase/carter" but not the actual connection. The first one comes off a tee from the solenoid and has a check valve on the line. It ends with "crankcase/solenoid". The shop manual has the hose labeled as connecting to the "vent from counterbalancing shaft oil cavity". I've seen that vent bib. The second one is the lower tube connected to the tube where you pour oil into the oil reservoir. I saw elsewhere in this forum where it was said this tube goes the the vent tube below the counterbalancing shaft. They both can't go there. Any help in clarifying this would be appreciated.
    Re: 2002 Seadoo GTX DI Hose Dilema
    Pictures would help.. The one with a T to the solenoid, sounds like it's for the rave valves solenoid??
    The second one, the oil tank vent should just come out of the tank, to a check valve and that's it.
    Dan Solie -
      I'll try and get some pictures. Maybe someone who has this ski can look for me so I can make sure. Don't want to bust a motor.
        I have 2 DI's about 15 feet from me... Send me reference pics and I'll go look
        Dan Solie -
          If you go to the parts list/drawings under "Oil Injection System" it is hose no. 27 that I'm trying to determine where it connects on the block. Also, in the "Air Intake System" I'm trying to find where the hose that comes straight down from the "tee" labeled no. 41 at the top of the page. Thanks for your help.
            27 goes to the small nipple under the air pump on the crank case. Its a return line back up to the oil filler neck.
              I cant see the pic of 41 that you are talking about.
                Under the Air Intake System section there is the rave solenoid. To the left is a "T" for the hoses. The one going straight down towards the motor is the one I'm talking about. There is a check valve on the hose in question.
                  That is probably the pulse line connection. Look under the air intake, on the case, there should be a nipple for that to hook to. NOT the counterbalance oil vent nipple.
                  Dan Solie -
                    I have some pictures I tried to send but they were too large for this forum. Is there any other way ot get them to you?
                      dans@designbyothers.com
                      Dan Solie -
