Rebuilt carbs, new plug wires, new plugs, Idles Great , Full Throttle Great, just bad acceleration. Almost have too pump throttle, then it acts like it wants to flood out. Once it's up and running full throttle and you let off it almost stalls out. Really stumped on this one, can anyone please help? Could it be the gap settings?
98 Sea-Doo GTX Limited Bad Acceleration
Re: 98 Sea-Doo GTX Limited Bad Acceleration
Carb settings or pop-off pressure may not be correct. If you still have the original pop-off springs try going back to them.SBT Tech Support is here to help with your problems.
Have played with carb settings in and out as much as one hole turn out past spec setting, does a little better. Found rav valves turned all the way in and turned them out til they were flush, didn't really notice a difference, top end is good. I'll try the original springs. Thanks a bunch!
Hey, if you need anything for that 98 gtx; I have one I am parting out...I blew my motor last month and it is not worth replacing.
dtaghome@aol.com
