My RX is misfiring at low speed and idle quite a bit. What can I check?
2001 Seadoo RX Misfiring
Re: 2001 Seadoo RX Misfiring
Spark plug (fouling), spark plug wire (remove cap and cut 1/4 off wire and re-install the boot), old fuel in tank, voltage regulator failing, poor engine ground.SBT Tech Support is here to help with your problems.
