SBT,
Trying to remove the ride plate to fix a little crack in the hull along the plate. Any tips on getting it off? Is there some sort of trick with a wedge ? The manuel I have says you need to remove the pump but on this gtx rfi the plate is not attached at all to the pump or pump support.
Also what is good to re-seal it once I put it back on?
Thanks,
davidj
Thanks,
davidj
