have a 1997 speedster. one engine wouldnt give full power. did a compression check. one had 135 psi the other around 120 psi. took the top end off and the pistons, rings and cylinder look fine. could low oil cause this? do i need new cylinders and pistons or try just new rings?
thanks
thanks
