2002 seadoo gti le all of a sudden no spark
  • 2002 seadoo gti le all of a sudden no spark
    Last week i had my 02 gti le out and out of no where out in the gulf it died on me, after a few minutes cranking it over it started and went about 20ft and died again.i initially thought i was just out of gas and my reserve was not working....i went ahead and stopped in at sbt and got a new wear ring and drive shaft rebuild..once done i filled it with gas and still no start.. Upon further inspection i learned i have no spark. There is a verry small pulsing current going to the coil while cranking it over (about 3v)..new plugs, and all fuses are good.
    Re: 2002 seadoo gti le all of a sudden no spark
    Check your grounds and ground wires, snip the plug wires back 1/4" to reveal fresh copper, how is the battery?
    Dan Solie -
      My ski only has one main ground wire from the battery to the block, the coil has a few grounds on it and all are good. Ill try the wire trick...im not sure what the voltage should be to the coil but it did get a little bit. I took the magneto cover off but looks like i need to get some more tools to pull the flywheel off...
