I have just installed a rebuilt 787 rfi. I have run the diagnostic scan tool with no faults and reset the TPS with the tool. THe original TPS showed 7.6. now after the reset it shows -0.4 and runs much better I have 2 identical 2003 GTI LE RFIs. the other skis shows -4.4 and 3.6 for its TPS. It runs fine.
THe problem I am having is the new rebuilt engine runs fine at full power and all the way down to idle and back up as long as I use a smooth throttle pressure on acceleration. If I pull the throttle to full open very quickly, the ski does not accelerate and produces a lot of smoke. the spark plugs show rich mixture again an RFI engine no carb. eventually after maybe 7 seconds the ski takes off and accelerates to full power, this only happens on a quick pull of the throttle, a smooth pull has no problems and if a pull hard and the engine bogs down at low RPM then if I release the throttle to 1/4 and pull smoothly it recovers to full power. MY other ski same model will pull you out of bed with no hesitation when i applied zero to full throttle instantly. I have tried swapping rave valves swapping computers and new spark plugs, again the same problem persists. I also had the problem before I replaced the rebuilt engine. Any input on this problem would be greatly apppreciated to point me in the right direction for troubleshooting
